Storing Danforth on bow roller
afc208
Does anyone have a good method of lashing a 13 lb Danforth anchor to a bow roller? The roller is a single type with a U shaped shackle(?)going over the roller; I'm sure you've seen them.<br />Thanks.
sloopy
Re: Storing Danforth on bow roller
when the line is pulled up a chain tightener is pushed down and it stays.
Pursuit2150
Check the marine stores, there a bracket avail. for that purpose.
Solittle
I have a small bracket that looks like the hook on the end of the line from your winch to your boat. I put a link from the chain attached to the anchor over the hook. The open end of the hook is facing the stern. It has a spring in it to lock the link in place. <br /><br />The thought of the anchor letting go as I am running down the turnpike is not pleasent.
dogface
If ya don't want to mess with using a bracket designed for that just put a length of line through a link or hole in the anchor and tie to a cleat. Works for me.<br />Dave
