Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Transom height terms
  • Transom height terms
    What do LS and SS mean for a transom height. I am seeing this on Smokeercraft's Alaskan model.Thanks
    Re: Transom height terms
    LS is long shaft or 20" models (top of transom to keel).SS is short shaft or 15" models.XL is extra- long or 25" and XXL is 30".
    • #3
      Thanks for the info.How could a boat be able to use both?
      • #4
        Not sure what you mean. The transom height is either 15" or 20" or 25" or 30". Its usually not easily changed.What is it that they say?
        • #5
          Length 11'10" Beam 63" Depth 24" Interior Depth 19" Transom Width 56" Transom Height LS/SS Dry Weight lbs. 185 Max Persons 3 Max Capacity lbs. 700 Max HP 15 Fuel Capacity gal. N/A Bottom Gauge 0.064 Side Gauge 0.060 Rib Gauge 0.064 http://www.smokercraft.com/utilities...uxe12tllxs.htm
          • #6
            One example is the Boston Whaler Outrage-18 of the 80s.Single engine. . . 25" or extra long shaft.Twins. . . 20" (long) shaft engines.5" of deadrise between center of transom and the outer portions where twins would mount.
            sigpic
            • #7
              A 56" wide transom would suggest twin motor capability. sounds like JB knows the score
              '71 Seaking resto http://forums.iboats.com/boat-restor...ion-62912.html
              • #8
                Whooops..
                Rick
                "Boating is Life...All the rest is just Details"
                2007 Bentley 200 Cruise
                2007 Merc. 90 4 stroke
                • #9
                  Maybe with twin 7.5 HP's....
                  Rick
                  • #10
                    Now years ago it seems there were some boats around with 18" transoms. Maybe thats what they mean. It'd be worth a call to see....
                    • #11
                      You might be right, Dhadley. Noticed that the "Interior" depth is 19"....
                      Rick
                      • #12
                        Thanks for all the info. I will call a SC dealer south of me and see what they say. I just can't imagine two motors on a 12' boat with a 15hp max. Maybe you could order either way. I will find out.Thanks again for the info.
                        • #13
                          What they mean is you can get it with a 15" transom or a 20" transom. The choice is yours. Twins on a 12 ft boat? I think not.
