Re: Quicksilver 3000 Classic side mount control box
Ok, wanted to double check the instructions as its been quite a while since I've done this.<br /><br />Push the throttle only button in and push the throttle forward. Now pull out the throttle only button and remove it. <br />It pops out.<br /><br />This will reveal a hex head bolt, remove it and the handle should pull off. Them separate the handle in half. That bolt should get some Loctite when you put it back in.
