Grumman Deck Boat
Status
Not open for further replies.
sbush
We have recently purchased a 97 Grumman 19 ft. sport deck. After searching for where exessive water was coming in we found a crack (15") in the aluminum at the bottom of the hull. It was under the rubber moulding and had previously been welded. Has this been a problem with this model and does anyone know the proper way this should be repaired? Thanks
appleo
Hi can you share where the crack was any pics? How did you repair it?
I don't see any rubber molding on my sportdeck
Watermann
14 years ago he posted that and has only that one single post... :eek:
Status
