Hello everyone,,
I have a 2004 19 foot Skeeter with a Yamaha 150 4 stroke and I have a lot of trouble with porpoising. I can get it to run smoothly as long as I have it trimmed up on the pad and I run at 4000 rpm or higher. Once I drop below 4000, it starts porpoising. I can trim it down and it doesn't stop. Once it is completely trimmed down, it is better, but not entirely gone. Doesn't matter if the water is rough or smooth. If it drops below 4000, it's going to porpoise regardless of where the trim is. I can't move weight forward, batteries, etc., because there is nowhere to put it. The boat uses 4 batteries and has a 32 gallon tank. I've even let the gas get down to a quarter of a tank to eliminate fuel weight and it didn't help at all. I've thought about getting a fin to mount on the cavitation plate. Any ideas would be greatly appreciated.
