Grumman Square Stern 17S
BeauWegmann
Thanks to Craigslist, recently purchased a square stern 17’canoe. While researching found yalls site and closed thread about compiling a database of Grumman canoe serial numbers and would like to add mine. 814-G-17S. Would like to know the general information about the model and if possible when it was built. The guy said he thought early 90’s, but not sure. Thanks
GA_Boater
Welcome aboard.
If the boat was built after 1971 it will have a Hull ID Number (HIN) located on the upper starboard corner of the stern or right around the corner on the side. It starts with 3 letters and has 9 numbers/letters following.
If it's from the 90's it definitely has a HIN assigned by Grumman or the Marathon Boat Group as they are now known.
Did you get any paperwork from the seller?
