Wondering what some of you use to shine up your boats?...i finally got a family boat and it has a lot of hard water spots esp on the dsrk green graphics, it also has some oxidation on the rear of the boat that would have been exposed to the most sunlight while sitting on a lift. I have been using a porter cable orbital polisher/buffer and some waxes...ive tried about 4 different ones i had in the cupboard. Even tried a couple that supposedly are designed to "cut" a little and be abrasive, but im not getting the results i want. Its looking better but id like to get rid of the water spots completely. So what product should i use? Should i be using a circular polisher instead of orbital? Also wonderinf if this product called "topcoat" really works. Supposedly you wipe it on and magically all the dirt grime and waterspots are gone.
