- Jul 18, 2011
- 17,696
I have my boat out of the water and up on blocks/stands for the winter. While the nights are cool, but the days are still fairly warm, I took this opportunity to do an 'inspection' of the hull of my boat with my FLIR One IR Camera.
Here are a few photos
#1)
This was a 'cold' area in the bow. It turned out that the water tank compartment was actually full of water (surrounding the tank) I took care of it with a wet vac.
#2)
This is the mid-cabin area, and I was a bit surprised by the 'cold' square area. The area just below it is the mid-cabin 'mini-bilge' that is right at the bulkhead. there happened to be a little bit of standing water, as the drain is up an inch or so from the keel. The really dark are seems to be just under the head compartment and in an area where the shower drain is located. I have not used the shower, but maybe the drain has been leaking in the past. :noidea:
#3)
Here is another angle of the mid-cabin area. If I replace the cabin carpet/floor . . . this whole area is probably worth a look.
The rest of the boat seems to be in decent shape. The transom looks good. . .
4#)
#1)
#2)
#3)
4#)
