turbocorrado
- Aug 14, 2013
- 251
so i just picked up a 1998 wellcraft 240se. boat is really clean for the most part. on the port side of the boat, the small cabin window towards the front leaks. can i just pull it out and use some silicone sealer or is there gaskets for these? also are these all generally the same size on all boats? as in would it be easy to find replacements or should i lose that idea
oddly enough the one that looks ****ty on the outside is sealed, its the one in front of it that is leaking into the boat
https://i.imgur.com/7uR4f7ml.jpg
