Blind Date
- Mar 5, 2014
- 462
An engine from the 90's, probably hasnt been replaced from new.. they dont last forever.
Pretty sure the engine pumps don' wear out. The bearing fails and they leak but there is nothing with the pump itself to wear out unless the impeller has corroded to nothing. Maybe in that salt water crap but unlikely in a fresh water boat. In addition the engine pump doesn't do squat anyways, that's why they make kits to completely remove them. The seawater pump can easily move enough water through the engine & manifolds to keep everything at operating temp.
In an older boat/motor I'd be looking for a blockage some place due to corrosion and would start at the risers. I suspect the engine pump is just fine and not the reason for the overheating issue.
