wassup iboats! new boat owner. unfortunately of course buying a cheaper boat always come with its prices. this was the bill i got from the mecanic. as i dont have any idea what these things cost. i just want to know wat you folks thought about it. i took the boat in because it was not shiftiing correctly. hard to get into gear and would die out in reverse. please let me know if this was a fair price or if i was getting upcharged. thanks guys! its a omc cobra 4.3L btw. thank you! i cant seem to load the picture from my phone. says the image is to large to load the bill. but i will just break down the bill here for you guys
inspection: 1 hr. 125$/hr
shift cable: 185$
ujoint bellow:65$
water pump:60$
gear lube: 60$
labor: 4hrs 500$
total:975$
labor description: inspect and advise- shift very stiff run test and shift interrupter staying activated too much stress on cable. drive making noise recommend further teardowb. remove outdrive disasemble and inspect for damage and advise. found bad shift cable,replace cable assy. also water in lower unit and fluid very black. service outdrive with new fluid and reinstall outdrive and adjusr shift.
shift cable: 185$
ujoint bellow:65$
water pump:60$
gear lube: 60$
labor: 4hrs 500$
total:975$
