Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
stronger oarlock
  • stronger oarlock
    I would like some advice for STRONG oarlock. Round, 2 1/4 diameter, 1/2" shaft. I have now broken two bronze and one galvanized. Rowing a 15' Chesapeake Light Craft Chester Yawl with 7 1/2 foot Shaw & Tenney flat oars (not spoon)
    The bronze ones have bent at top of shaft and then finally break. Yesterday a galvanized oarlock just snapped at the same place on the second pull from stand still.
    And seriously, how much strain can this 68 y.o. 165 lb retiree put on an oar lock ? Sure, trying to perfect the Thames Waterman's Stroke, but still, snapping oarlocks ?
    Certainly someone must make something that can withstand a few foot-pounds of pull.
    TIA
    Go stainless steel
    Best regards, Ted . . . . Cape Cod, MA
    Formula 330 Sun Sport, O'Day Mariner Sail #3224, Sunfish
    Past Boats: Catalina 22 Sail #10531, Formula 242 Sun Sport
    Twin Mercruiser 7.4 LX MPI (0F802036, 039), Bravo 3's (0F806198, 199), Mercury 7.5 HP (1969), Johnson 4.5 HP (1980)
    My Boating Web Pages: http://www.tpenfield.com
    Member of the Month - February 2013
    • #3
      You must be one strong old man. Seriously though, the brass and galvanized will be cast. They will break under your tremendous strength. Stainless cannot be cast, only machined. You will not break stainless.
      • #4
        Stainless is cast everyday. We use many stainless castings at work....and stainless is not as strong as steel.
        Forged aluminum would be stronger than cast. I would find a fabricator to turn some out of aquamet 22
        1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - http://forums.iboats.com/forum/owner...988-rogue-2420
        Past Boats
        1970 Wooster Hellion - Merc 9.8
        2002 SeaRay 190BR - 5.0 - A1G2 - "Cheasheads in Paradise"
        1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
        What’s behind you doesn’t matter.Enzo Ferrari
        • #5
          You can buy much stronger oar locks, just look at the white water rafting stuff, they will cost more though.
          http://www.paddlesandoars.com/OAR-ACCESSORIES/
          https://www.nrs.com/category/3146/ra...ockspins-clips
          • #6
            [QUOTE=Scott Danforth;n10495445]Stainless is cast everyday. We use many stainless castings at work....
            I stand corrected and I apologize for the mis-statement.
            • #7
              Thank you all. Bought some stainless at West Marine and also ordered some Perko bronze. At least with bronze I've experienced they will bend over time so with diligence I can replace and not be caught up the proverbial creek without a 'paddle'. (I do carry a spar oar and lock ready to switch out)
              Scott Danforth: it may take some time to locate a fabricator - but I will keep it in mind. A fiend speaks of someone who might be up to the task.
              ondarvr: thanks for those links. Didn't seem to offer what I am looking for - but definitely appeared to be strongly constructed.
