I was told once that prior to winter storage for the boat (Outside but covered) I should put in stabilizer, run the engine for a while then fill the tank completely. I was told that filling the tank helps prevent moisture. I am curious, does everyone else fill their tank or leave it empty or close to empty (assuming you are storing your boat outside).
Joe
Joe
