I recently picked up a '69 Silverline Riviera, as the first boat I've owned. I grew up on the water, but only running Dad's old Thunderbird that he sold when I was a teenager, and have been off the water since, which was about 20 years ago. So I'm largely relearning it all again, and learning new things as well. Such as today, I learned that not all hydraulic set ups are both tilt and trim, which explained why my motor wouldn't trim up at anything above idle speeds, and would slam back down if I tried trimming it up then applying power. I also learned what the goofy looking J pin that I found in the gunwale storage was for - manual trim pin.
There is also a lever on the port side of the motor, labeled tilt on one side of the handle, and run on the other side. I assume this would be set to run to lock the motor on to the trim pin when installed to prevent the motor from tilting itself up in reverse, and set to tilt when I need to raise the motor to put it on the trailer, but I ran it all day today with the trim pin removed, and never noticed the motor wanting to tilt up even under a decent amount of throttle in reverse (this was before I realized I need have that pin installed for trim purposes, and still thought I had power trim) Does the hydraulic tilt unit keep the motor from tilting on it's own? As such, should I still be putting the lever in run next time out when I do have the trim pin installed? I forsee myself forgetting to flip it one day when putting it back on the trailer, and afraid I may cause damage to something.
