Hi,
I have a 2003 Regal Comodore 2860. The fuel gauge doesn't work. I checked the fuel sender and it seems like the rod came off (you can see a thin rod w diodes in direct contact w the fuel). The rod measures 13" .
I can order a new fuel sender (I think just another wema 13" should be fine).
Here is my question:
Do i need to worry about the rod/float that should be rolling inside the tank?
Also, should i cut the rod ASAP (while i wait for the new sender)? Maybe those diodes (in direct contact w fuel) could get damaged and contamina the tank/fuel.
Thanks!
Thanks!
