Hildebrand
- Mar 29, 2016
- 129
Hi , I hope this is the right section as I'm new to this site. I've also searched the site some for this.
90 four winns 225 sundowner, and my trim tabs are acting up. They are Bennett trim tabs. The starboard side goes down but won't retract , but the port side works fine. Once it was stuck down I bled the system and it retracted. After that I swapped the solenoids and the issue went to the other side. Would this be a bad solenoid? The battery's are only a 2 months and the boat starts up and everything else works fine.
