Ugg.. That's not good. Your deck is rotting. If it's just cracked from stress you are very lucky it can be fixed. If rot, you will have to check the stringers, transom and things like that. They rot from the bottom up to the deck.
They do not spin, seem to tighten all the way down - with using a hand driver at least.What happens when you try to tighten those screws into the deck? Do they just spin without getting tighter?
I would remove the base and see why it's wonky.
I would do more excavation. Cut out the semi circle of glass and see what that aluminum plate below is doing. I was going to go from there but it's all a moot point before looking at what's below. Are the fasteners self tapping or machine bolts? There may be a number of things gone bad. I would look first.
Nota Bene, I am not a glass expert though, I'm sure someone will hopefully chime in that is a glass guy.
Just a guess here, It looks like it could be a cored deck, and the bolts were not sealed, allowing water to get in the core and rot it away. Hopefully it's just in that area that's bad. Cut it a bit and see what ya got going on.
