On a buoy, or a slip where you can't get on all sides of the boat, most people on the 2 lakes I boat on use the snap in cockpit cover. On slips where you can get on both sides, then they go with the cover on the bottom photo.
I made the bottom cover longer on the sides to cover the blue gel coat. I could have made it a lot shorter on the sides and it would work in a slip.
