- Mar 8, 2009
- 40,718
The port side trim cylinder needs repaired. It is cracked on the left side top and leaking fluid. The boat is a 1994 model so its kind of old. Looks like I can get the upper actuator hinge, just looking for the best repair and not necessarily the cheapest. Most the time I don't even use the tabs, but last weekend had several folks and a lot of weight. There is no corrosion and is in fresh water
Hey Tabman and others looking for recommendations?
