adam lancia
- May 13, 2017
- 7
My family is going to be making the trek from Alabama back to Nova Scotia, across to Toronto, then back to Alabama this summer. We looked into buying a utility trailer, then renting one, then decided that didn't make much sense. So here's where we're at with it now:
We figured that we won't have room for everything in our small SUV for the long drive back to Canada this summer (next week actually), and aren't really thrilled about spending money on a utility trailer. So we decided to look at cheap boats and found a 15' 1972 Terry Bass Boat with a 40hp Johnson 40EL-73D outboard and a 40lb MinnKota Edge (brand new battery too). It's listed as weighing 835 lbs without any other equipment on it. The stick steer is kind of cool (works, even the manual tension adjuster), and the fact that it has a flat floor with a fair amount of room is a big plus. The engine started right up but needs an electric choke override lever (an $11 part online from what I've seen). The trailer has new tires, bearing buddy's and freshly packed bearings, and it tilts. The guy had it on the water in March to ensure it ran and didn't take on water (passed both tests I'm told but he said he'll take me out on Monday for further proof). I think we're going to make an offer on the boat for the simple fact that we'd be killing 2 birds with one stone. It'll be big enough to haul the extra stuff that won't fit in the car for the trip back, and we'll have a boat!
There were a couple of small dings in the front center of the hull, presumably from being driven up on shore. The transom looks good, no rot or cracks that I could see. What else do you think I need to look for once we get on the water?
Lastly, and probably most importantly considering the drive we're about to do: how does towing capacity translate into actual weight of all items being towed...? Is there anything I need to be especially considerate of when towing? Obviously we won't be able to travel as quickly as we would without it behind us, but what else? I'll register it here in Alabama before we leave, what kind of documentation do I need to bring in order to cross into Canada and back into the U.S.? Do I need insurance for the boat/trailer as in Canada, or am I covered by my car insurance while towing it...? Is there anything else I need to take into consideration?
https://tuscaloosa.craigslist.org/boa/6121706823.html
Thanks!!!
Thanks!!!
