I only found one fuse in any of my engines and it was 20A. 20A can be run with 14 ga hookup wire for short runs, especially with intermittent loads when not tied up in a harness where heat can't get out. Problem is insulating melting. Fusing current where the wire melts is like 20+ x the normal load.
