Fuse Size Question
swampjam
I have a 1982 Monark McFast. I have attached a photo of the wiring diagram. I'm hoping that someone can tell me the size of the inline fuse shown in the upper left of the diagram. Thankswire diagram - Edited.jpg
Texasmark
I only found one fuse in any of my engines and it was 20A. 20A can be run with 14 ga hookup wire for short runs, especially with intermittent loads when not tied up in a harness where heat can't get out. Problem is insulating melting. Fusing current where the wire melts is like 20+ x the normal load.
