Theoretically, can I just pull the engine kill switch to disable the ignition system when performing a compression test? And just use a vice grip to clamp shut the fuel line so no fuel gets pumped into the cylinders? Also is the proper procedure to pull all spark plugs and wires when doing the compression test or just pull each plug one by one and do the compression test as you go?
