Ok this could be a dumb question, I bought this 05 lowe 170w and I haven't had it in the water yet but I'm curious how does the front livewell fill? The rear livewell has a little spray bar but the front has no spray bar just a hole in the bottom?
There may not be a "spray BAR" but rather a "nozzle" that might be hidden by the ledge around the compartment. Stick your head in there and take a "good" look. No bar or nozzle -- you have a cooler and not a livewell. It it is a livewell, you would need a standpipe that sits in the hole in the bottom. If you don't know what a standpipe is, lift the lid on your toilet tank. That "overflow" pipe is a standpipe. It works the same way in your boat.
