ajgraz
- Mar 1, 2010
- 1,858
I found that the way my small built-in livewell is constructed, water sloshes over the upper "lip" of it (under the hull "cap") into the bilge.
(I actually found a thread almost exactly describing my issue on another boating forum, but I don't know if I'm allowed to link that, plus I was not entirely happy with the answers there)
So, should I try to seal that upper lip to the bottom of the hull cap? If so, what are some good ideas on sealant to use?
Or, should I just let the bilge pump float switch take care of that as the manufacturer apparently intended?
