Hello All,
my name is Dave, I'm from the Sweetest Place on Earth, Hershey PA and I'm darn glad I found this forum!
I'm a newbie to the site and a newbie to boating! I love to fish and been on boats but never owned one until recently. I bought a 1999 Lowe Fish and Ski Sea Nymph GLS 190 that was a PA Boat and Fish Commission patrol boat that I purchased through auction. The boat had been sitting outside for the past 4-5 years after the original motor an 1999 Evinrude 175hp FICHT seized up. I've since put a 2003 Johnson 150hp on it.
The boat seems sound and based on all the water that poured out once I removed the plug, the hull is sound. Cosmetically, well it looks like a boat that has been sitting outside not covered for 4 or 5 years. I'm anxious to get started with painting and installing new carpets, however it can get very cold up here and I need to be patient until spring. So while I wait, I'm trying to find out as much as possible about this boat however I can't find much info on the GLS 190 at all. And since I'm a newbie to owning a boat, and I have no clue on what I should be doing with this boat, I figured I'd ask all of you for the help!
I've also attached pictures (I hope) of the boat that may help with your advice.
Questions
1) Gas Tank - How can I tell if there is any sludge in the gas tank? It is a poly gas tank and I did pump about a gallon of gas before my hand pump tied. (Hope to get my mini electric Monday) Gas looked good and I ran it in my mower with no problem. I still plan on pumping all the gas out and fill with fresh gas but prior to doing so, I'd like to make sure the tank doesn't contain any sludge or water.
2) Wiring - Is there somewhere on this site or elsewhere that I can find a wiring diagram for this boat? I've searched for a manual and can't find anything. I hope to pull carpet and when I have it off would like to remove any unneeded wiring or run wiring I may need but it doesn't currently have. I believe boat had VHF and possibly other electronics based on wires under lefthand dash. (Picture attached)
3) ICU Injection - there are face plates in the front and back of boat. Not sure what they are. I did search the forum and someone posted a website but it is no longer valid. (post from 2010) I've attached picture below.
4) Re-enforcement plates - So the front of the hull has what looks to be pieces of metal at the front of the hull. Someone more knowledgeable than me stated they were re-enforcement plates? I've never heard of them and wanted to see if there is indeed enforcement plates for the hull?
5) Carpeting - Can indoor/outdoor carpeting be used on the boat? I've seen quite a bit of discussions on the forum on marine carpet vs outdoor carpet but it seems like there is not definitive acknowledgement stating outdoor can be used. (I'm on a budget and if outdoor will last for 4-6 years before I re-carpet that would work for me!)
6) Paint and Prep - what type of paint can be used on the hull under the water line? What type of paint for above water line? I do understand I should use a primer with zinc chromate, however is there specific paints I need for hull for above and under water line?
7) Water line - Is there a way to determine water line without putting the boat in the water?
8) Trolling motor - I have no idea what size and or what the front panel is for. (Picture attached) will 55/lb thrust work? I found one for sale with 60 inch shaft.
Hopefully pictures are attached below.
I appreciate any advice and help you can offer.
Dave
Questions
Dave
