A helical anchor, however, could not be pulled out and the strain gauge recorded 12,000 pounds of pull ? its maximum ? before a shackle burst apart. (In an earlier test with a larger tug, a strain gauge registered 20,800 pounds before the hawser snapped...
Yes, those are impressive numbers, but will the boat hardware stand up? All the anchors in the world won't help when the strain from massive waves rips off the boat hardware.
In Tampa, you will probably OK - This time.
From what I have read anchor rode elasticity is the solution and that makes sense because I know in the past when I have used a tow chain to pull one vehicle with another its really shocking when the slack gets taken up the a chain and it jolts both vehicles but if you use a tow rope it is not nearly as bad.
At the dock I keep the boat tied with 5/8" Double Braid Nylon Line, 13,500lb. Breaking Strength and in parallel to those lines I have White 3-Strand Nylon, 1/4'' Diameter, 2000lb. Breaking Strength I am guessing about a foot shorter.
The 1/4 inch line does all the holding till it stretches from wind or boat wakes to the point the 5/8" Double Braid becomes tight and does the holding.
I came up with this idea when the wind and waves were hitting the sailboat on the end tied by a short length of like 3/4 Double Braid and I could feel the whole dock moving on each bounce because the pilings are in bad shape all eaten up by worms.
When I tied a shorter length of 1/4 inch in parallel to the bouncing sailboat the elasticity totally prevented that jolting of the dock, it worked so well I went and bought enough to run it in parallel to all my lines.
Good elasticity should save the boat hardware, I am imagining pulling out a thumbtack with a rubber band vs a foot of fishing line. The fishing string I could yank it right out but with a skinny rubber band it would be different.
2 fishing weights one tied to a thumbtack on a bulletin board with rubber bands the other just fishing line I imagine dropping the weight the thumbtack would hold with the rubber band but not with just the line.
