I had another look at where the wires go in, there's a rubber boot around the cables crimping them together, I removed it and had a feel around inside the cavity, it seems to just be a void as in no 'tube' to run the wires through, my concern would be if i pushed any fish wire in through the hole it'd just get lost in the cavity and be impossible to get it to the other opening as it doesn't have a tube to run through, would this happen ?
Thanks again
Okay, wait a second, you still can run your cable with the rest of the wires. Remove one wire that is going to the helm area or where ever you want the new cable to go, and tie a string onto it. Now pull that wire back to the boot area. Then attach your new cable to the wire and string and pull it back to the front. Bingo, new wire run with the rest of them. JMHO
