I just bought a 23' CC which is in dire need of trim tabs so I'm about to install some. I have a small issue though:
I know the red line in the attached photo is the recommended location, but if I install there then the actuator will foul the ladder platform. I can move the ladder up, but prefer not to add too many new perforations to my transom! Besides, having the ladder platform higher will be a little odd, but not unbearable.
Will I have a noticeable problem if I install where the blue line is? I can see that this boat used to have tabs actually, and the blue line is where they were installed previously.
What do you think? Suck it up, move the ladder and choose the red spot? Or compromise on the blue spot since that'll be good enough?
Thanks for any and all advice! ~Adrian.
