Still trying to track down this leak. The boat is 31 years old and im sure the transom does have some rot, but i want to find where this water is coming in i have sealed all swim platform bolts trim tabs bolts and underwater lights with 5200 and the leak is still now different? There is silicone around the gimbal housing where it goes through the hull could it be coming in there? The blisters in the fiberglass where the water is coming in is high up, i did fill the bilge but the leak is to high on the transom for the water in the bilge to reach. I did find water dripping from a hole on the gimbal housing where the trim lines attach.
You can see the water ready to drip from the hole this is with the bilge filled and boat tipped up on the trailer. The other pictures are when the boat is in the water.
