dbatchelet
- Aug 27, 2016
- 1
I'd like to know when my purchased used 14' Aluma Craft fishing boat was manufactured. The serial number is: ACBH3001M76F
FromHIN Search results:
Success! ACBH3001M76F is of the standard HIN type called Model-Year HIN. If you are buying this boat/craft then you should get the boat history and Boat Insurance from the BoatU.S. Program.
ACB HIN Decoder
Our HULL ID Decoder breaks down the Hull identification number into the following information:
The HIN or CIN you have entered meets the Model-Year HIN format. It might also be a type that contains the country code and thus the boat comes from USA or Other . The serial number of the HIN is H3001 and is set by the boat builder. This boat or vessel has a Certification Date of (76) and a Model Year of 76 with month of build (January) based on the formatting of your hull_identification_number (HIN) .
The manufacturer identification code (MIC) of your craft identification number (CIN or HIN) is ACB. This MIC (ACB) stands for the company name Alumacraft Boat Co which is currently In Business. This boat manufacturer has other company names (ACB sometimes goes by these name(s) , , , or .
This company (Alumacraft Boat Co) is owned by Randy Mathwig and is located at 315 WEST ST. JULIEN in ST. PETER state of MN. It manufactured this vessel and placed you HIN or CIN on the hull. The Parent Company for this boat maker is (). Alumacraft Boat Co has started making boats, yachts and other watercraft as of 04/10/1974 0:00.
Make sure to compare the date of boat manufacturing with the dates in which the company was actually in business.
The US Coast guard provides this comment about this watercraft manufacturer: Arkansas Plant Using (acb) Also. 001016 New Poc At Arkansas Location; Was Larry Gardner.-050617-update Ppg. Poc Mn Was Charlie Nelson. Nnma Certified..
More details at the US Coast Guard.
If you are purchasing this boat/hull then get the Boat History here or the BoatFax Report to complement it.
There are 4 boat Recalls for Alumacraft Boat Co your vessel:
Alumacraft Boat Co Boat Recalls for your HIN and MIC: 4.
