Easiest thing to check is have it weighed, if your a few hundred pounds heavy then you have a water logged hull. All the flooring must be removed to get the old wet foam out. Numerous rebuilds in that forum area to show you what your looking at. Could also be the weight distribution inside your boat...nothing will be right until you get the correct ratio and prop and go from there. I have an 83' Islander with the 140 hp 3.0 and she will do 34/35 mph by gps with 2 adults with all the fishing gear, full tank of fuel and a kicker motor. I have my weight distributed well as she planes fairly quick.
