ok,,,thanx all !
hmmm...the temp idea is something I hadnt considered !
If ya dont install a thru-hull...
I assume your "rigging" a hose or pvc(?) over the transom. ?
Would this/does this still keep water pumping to the tank as your underway to the fishin grounds ?
I generally cruise at about half throttle,,,depends on the sea.
