I just bought this and it has been used in salt water. I will be mainly using it in fresh water with an occasional trip to the gulf. It has an anode installed on the hull. There is a wire from the anode that is not connected to anything. Do I connect it to the negative battery post?
Next The plastic fuel tank was uninstalled. I am reinstalling it and do I need to run a sepaerate ground wire to the sending unit besides using just the two wires from the sending unit itself?
Thanks.
Thanks.
