muskyfins
- Jun 7, 2012
- 578
Hey folks. Hope someone can help me.
Need to replace my fuel fill thru hull fitting on 94 Rinker 265 Fiesta Vee cruiser. It screws on from the outside of the hull aft of the rear bench seat on the port side. mounted on what I would describe as the aft section of gunwale. (pics tomorrow I promise). The OEM plastic unit is cracked and Im planning on replacing with a SS part, but how are you supposed to get up there to unscrew the hose clamp? It is at least 12" or more like 18" from the closest access point. Already looked at unscrewing it from the glass and pulling up an out but the hose clamp is too big to pass thru the opening. Am I missing something? Thanks.
