My VP SX outdrive leg was missing the anode when I bought our boat (the transom plate has an anode) a couple years ago and I am now getting far enough down the list of repairs to think about the anode. For background, this boat sees about 2-3 weeks of day use only per year and is put on the trailer at the end of each outing - never slipped at the marina or left in the water overnight so I am sorta on the fence about whether an anode is truly necessary or not but I suppose it's better to be safe than sorry for a few $.
The VP anode kits with the transom anode and leg anode come with hardware but the individual outdrive leg anodes (VP) apparently do not. Since I am planning on only installing the anode on the leg I will need to buy my own hardware separately. What type of hardware should I use? Is plain old stainless steel bolts ok?
Since we boat exclusively in freshwater inland lakes it will be a magnesium anode, in case that makes a difference.
Also, if you have any tips on installation process that would be great. I've never dealt with anodes before.
