shackle101
- Jan 11, 2012
- 140
Model I have: Nauticus SX10512-90. I've called Nauticus and got some recommendations from them, but just wanted to post a thread about it as well and see what folks think as I got the impression he wasn't too certain about the install or how well it will work for me (said I may need to go to 70lbs). My biggest concern is where to install them. He told me it would be fine to install them either way I want, but he did some more research and kind of backtracked and said to install it so I can get it on the transom more so than the swim platform part which is a bit more at the angle. Problem is if I get it on the transom I have to go about a foot and a half in from the ends. He told me it should be fine on the swim platform regardless, but I wanted to check with you guys as well.
Pictures attached that better explain the situation. Anyone else have this boat, and installed these? I seen one forum on here where a guy was having tons of issues, but my boat isn't that bad without them now. Just poor hole shot. Before I start putting holes in it I want to make sure it's done the best way possible.
Thanks!
Thanks!
