maverick7687
- May 4, 2016
- 8
Picked up this 2000 196 from a family member. She said it "needs some work" so I am checking it out now to see what all it needs.
This boat has been passed around between Aunts and Uncles in my family for about 7 years and it's always been a great boat so I hate to see it not taken care of like it should be, and I just kinda wanted a boat.
The stitching on the rear bench seat has busted open so that will be a repair that I am not equipped to complete.
When I went to look at it and pick it up it had been sitting for almost a year. It was parked on an incline and I noticed water standing against the riser for the rear seat. When I opened the engine compartment it became painfully apparent that someone had left the plug in and the boat had been rained on, a lot. There was water up to the spark plugs on the engine.
I went ahead and pulled the plug and brought her home to Tennessee.
Engine
After it was cleaned up a little I turned the engine over to make sure it wasn't hydro-locked, all was good so I tried to fire it up. No dice. It would turn over and "cough" a little but never actually start. I pulled a plug to check for fire (I put some fresh gas in the carb and still no luck) and it was firing, but the plug looked awful. I got a new set and cranked her over and she fired right up. For about 45 seconds, dam. Started it up again and when it started to choke out I kept pouring fuel into the carb from a bottle and sure enough, it would run as long as I would supply the fuel. Time to break out the fuel pressure gauge. Fuel pressure would jump to about 7psi while cranking then fade away slowly. That's where we stand on the engine. New fuel pump and filter are ordered and should be here Friday.
Drive
No trim/tilt. The Up/Down buttons don't work, but the Trailer button works. Tells me the motor is running, great!
Climbed down with the motor and jumped from +12 to the wires on the pump and both Up and Down function normally. When the drive was going down a yellow foamy liquid started leaking from the reservoir cap. It seems thin to be in a hydraulic system (to me, I don't know what goes in these yet) and is about the yellowish color of Great Stuff foam.
From the little research that I have done it seems like I need to pull the drive and check the gimbal bearing and bellows to make sure there is no water in them and possibly replace bellows.
In the little time it was running it didn't feel like the power steering was working either (I am assuming it has PS since it's hard to turn with the motor off, correct me if I'm wrong). I haven't looked into that much since it is still functional as-is.
This will be my first boat so I am completely ignorant about best practices and ways to do things. I am excited to learn about what makes these things tick and get her out on the water.
Click pictures to make bigger, didn't want to flood the post.
First glance when I went to pick it up:
Loaded up and ready for the trip from KY to TN (Only 100mi)
I have done a lot of cleaning on the interior and all the moldish looking spots seem to be coming clean. All the lights and electronics work (or at least seem to) with the exception of the hour meter on the tach. The radio gets power and turns on but no sound. Makes the "remember to take your faceplate" sound when you turn it off so I'm thinking it just needs a new head unit.
Engine
Drive
