Quick question for you guys, any input or advice would be great. Currently purchasing a 1999 searay sundancer that has one leaky top deck hatch and 2 port and starboard oval shaped windows. Would you guys recommend that i remove them and reseal them or can i use Captain Tolleys Creeping Crack Cure? Leaks are not huge but do take on water and do cause water stains. I am willing to try the easier alternative which is the creeping crack cure and then reseal it if it doesn't help but how hard will it be to take out the window once the creeping crack cure drys? Thank You
