randomorbital
- May 28, 2015
- 3
Hi everybody,
I recently bought a small second hand boat and I had a look at the transom.
The drain plug that is currently has is this one:
The problem is that it is all that is has. On the other side of the transom there is a hole through the transom and nothing else.
I looked on ebay and didn't see any tube you could buy for this setup.
So basically I have this drain plug on the outer side of the transom and a hole with nothing on the inside.
Could anyone let me know if that is how it should be or not?
It is my first time owning a boat and I don't know if it's normal, it seems to be sealed with epoxy but it's an old boat so I was thinking of sealing the hole cavity with some sikaflex ( i have some on hand ).
I would love your input.
Cheers !
Cheers !
