Only 6? Mine holds around 16 plus ice. I take a small cooler for food.It is a through-hull fitting for a locker drain. Something fairly small. that looks about the same size as the one for the self-draining cooler in my cockpit. Mine hold about 6 beers, so it's completely useless. I store my mask and snorkel in it.
You can see the tail spar still jammed into the hole, holding on by fear. It needs to be removed and a new one rebidded. If the hose pulls what is left of the tail spar in, then you will have a hole in you boat letting water in.
Looks like .40 S&W to me.
Took me a while to figure it out on mine too. I was standing next to the boat on the trailer staring at it, and when it dawned on me I started laughing out loud. Anyone watching would have thought I was a certifiable nut.You guys were right. Glovebox doubles as a cooler and the drainpipe came loose.
