Thompson Carrara 2000 wiring
sboise
Looking to find out if the gauges are fuse protected and their amp rating
Ayuh,..... Welcome Aboard,.... Generally speakin', the gauges are usually powered by the ignition circuit, which should be fuse protected,.....
Whatcha tryin' to do,..??
sboise
On the bay my water temp never moved. I came home changed a couple of fuses. I hooked up my muffs to flush the engine with the house and water temp came up to about 150. The engine is a 4.3 vortex with an Alpha One. Any thoughts
sboise
Kevin, all the other gauges worked fine. It's strange that it worked fine at the house after I messed with the fuses. It's getting cold here and time to winterize. I will check it again then
