Pitot tube line broken
BigManDan72
The rubber tubin that connects to the pitot tube on my boat broke when I put the pitot tube down the other day. It's old and brittle I guess and it broke where the tubing bends. So can I splice a section of tubing in to connect the two broken pieces or would I be smarter to replace whole pitot tube assembly all the way into the boat?
gm280
I would replace the entire hose. It is not expensive and then you won't have to worry about it again for years. JMHO!
