No... It is not the surest way. Have you looked where the flotation foam is?
Of course I have, I'm not afraid to take my boat(s) apart and configure them to my liking.
This is my '98 Tracker Pro Deep V 17:
Notice how the foam is left out of the center above the keel, this is to ballast the boat in the center to give it stability and allow good drainage.
Notice the thickness and amount of foam in this pic:
This displaces water from the sides and keeps it over the keel for stability. Also note the limber holes for good drainage.
Not only is there foam below deck, there's foam above deck as well:
The rectangular "logs" outlined in red are also foam filled, this displaces more water should water rise above the decking in the bilge (but this has never happened to me). There is also ample foam in the bow area below the bow deck.
All this foam and it's careful placement gives my boat
upright and level floatation. This boat actually floats better than the Lund in the video because I have a smaller motor. How do I know this? Because I've launched with the bilge plug out (on several occasions). Water never rises above the decking, and since water never rises above the deck... I never notice that I've forgotten to put the plug in until after I've fished all day and put the boat back on the trailer and pulled it out of the water. After I pull the boat out of the water runs out of the bilge drain like a garden hose turned on wide open for several minutes. But since the foam is configured for good drainage all the water drains out and my foam stays nice and dry, after 17 yrs. my foam is dry as a bone and light as a feather.
This is my current "project" boat:
A 1967 MFG Corvette 2 CV
The Coast Guard tag states that the boat is equipped with
Positive Floatation, this isn't the same as upright and level floatation, positive floatation only means the boat won't sink to the bottom. It doesn't mean the boat will stay level and upright and it doesn't mean that the boat will only take on a small amount of water like the Lund in the video.
You can't really tell from these pics, but there wasn't that much foam in this boat (between the rotten stringers).
... but all of the old foam has been removed and new 2 part expanding urethane floatation will be installed... in larger quantities and with careful placement to ensure upright and level floatation. Yes it will cost more and be more work than just putting it back the way the boat was built back in 1967, but it will be an improvement and will add a greater margin of safety for myself and my passengers.
... and yes, I will test my floatation design in the same manner I described in my first post to this thread, there will also be a video made and it will be posted to this forum.
Here's a link to my re-do on my Tracker if anyone cares to take a look:
http://forums.iboats.com/forum/boat...-repair/521750-97-tracker-pro-deep-v-facelift
