I have a 1989, 85hp Force. When cold, it works perfectly, When warmed up, it works good up to 1800 rpm but starts to sputter above that and dies before hitting 2000 rpm. I changed the stator because the resistance reading were marginal. Checked out the fuel system for clogs. tore apart one carburetor, it was very clean. bought a used CDI, but one side was dead. swapped it with the CDI that only used the one side. same problem. swapped my original CDI with my other original CDI, still doesn't work. I don't think its a fuel problem because it happens at the same rpm consistently I could be wrong. Anyone else experience something like this and found a correction.
Thanks
Joe
Thanks
Joe
