Up on plane steers to starboard.
if ya have an adjastable anode. try this idea.
when ya set the trim tab, assumin ya have one. set it to your normal load, normal speed, and normal trim. with these conditions. it should steer straight and not pull one way or the other. steering is equal both directions. anything other than normal load, speed and trim. it will pull one way or the other.
on plane, trimming up generally make the steering lighter feeling.
at plowing speed, steering will feel heavy.
at idle speeds it should steer like it does in the driveway. no feeling of anything other than just turning the drive (ob) back and forth.
