beachedredneck
- Jul 26, 2015
- 2
93 115tlrr had it out running yesterday. Boat was up on plane without issue. Jumped off of plane to mess with my gps and when I went to speed back up motor would not go past 1900-2100rpm. If i tried to advance the throttle beyond that range, the motor will bog and die.
This issue is only when the boat is in forward. I ran it up to 4k in reverse just to see if it could do it, up to 5k in neutral with fast idle.
To me this says that I've got fuel, I've got spark and I've got compression. What I don't have is a clue what to look at to fix the issue.
