bwiilis228
- Jul 18, 2015
- 2
I have a 2004 Yamaha 225 ox66 with 126 gallon fuel tank. The motor seems to run fine with slick water and plenty of fuel. But it seems like once I get in rough water and the fuel is at a quarter tank or lower (30 gallons or less) that the motor dies. About a month ago we went to the oil rigs to fish. Went 40 miles had low oil. Filled oil went another 40 no problem. When we had about 30 left to go, we would run about 7 and it would die. It would Start right back up and run fine for another 7 -10 miles and die. It did that all the way back. Before trip I changed on board and racor filter, low pressure fuel pumps, spark plugs, cleaned o2 sensor. Not sure what would be causing this. Seemed like one the fuel started getting low and it started to get choppy or would ruin die, but always start right back up. This has happened several times over the last couple years. I am not sure what to do now. Any Suggestions Would greatly be appreciated.
