I have a 1990 yamaha precision blend 90 hp that I just got and I recently took it out on the water for the first time.
Went great for about 10 minutes with full power. I shut it down and let it set for about 20 minutes while I fished. Started it back up and ran terribly. Couldn't get over 25% power out of it and couldn't even get it up on plane.
Hooked a timing light on it when I got it home and discovered no spark on the top cylinder.
I swapped ignition coils hoping the problem would follow the suspect coil. It did not. I swapped the ignition coil and the problem stayed at the top cylinder.
I swapped the pulser coil with a known good one. That didn't change the no spark on #1 cylinder either.
I am at a loss. Does anyone have a way to test the cdi box? What else could it be?
Any help is appreciated!
