1990 yamaha cylinder 1 no spark
bryceb
I have a 1990 yamaha precision blend 90 hp that I just got and I recently took it out on the water for the first time.
Went great for about 10 minutes with full power. I shut it down and let it set for about 20 minutes while I fished. Started it back up and ran terribly. Couldn't get over 25% power out of it and couldn't even get it up on plane.
Hooked a timing light on it when I got it home and discovered no spark on the top cylinder.
I swapped ignition coils hoping the problem would follow the suspect coil. It did not. I swapped the ignition coil and the problem stayed at the top cylinder.
I swapped the pulser coil with a known good one. That didn't change the no spark on #1 cylinder either.
I am at a loss. Does anyone have a way to test the cdi box? What else could it be?
Any help is appreciated!
robert graham
Are you dead sure that top cylinder spark plug isn't fouled?...can't always tell just by a visual inspection....
99yam40
I would tend to believe the timing light if it shows spark on the other 2 plug wires but not on #1.
Did you see that?
I seem to remember #1 and #3 use pluser coil but #2 is generated by CDI.
I do not know what would kill just #1.
I would test the charge coil out put and the output of the CDI to all 3 coils to make sure what
was in spec and what was not
bryceb
Thank you for your responses. I'm dead certain #1 has no spark. The other two coil wires sting pretty good.
How do I test the charge coil output and output of the cdi? What specs are they supposed to be?
Again, thank you for the help
